im not sure what paint you would need but i know you would need a pressure can for applying the paint
Specs
https://linustechtips.com/topic/131920-gold-moded-chassis/#findComment-1755440
get it electroplated in gold! that would be amazing
https://linustechtips.com/topic/131920-gold-moded-chassis/#findComment-1755443
Hello, im planing a gold build and was wondering what sort of equiptment i need, any particular brand? What sort of paint to use? Any good gold paint out there?
Help appricieated
Thanky in advance.
Could use gold vinyl wrap.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/131920-gold-moded-chassis/#findComment-1755470
Hi,
Rorgash has the right idea,
Contact your local garage for cars and see if they know somewhere who would be willing to paint your case for you/would be able to do it themselves. As if you hand spray although it would turn out ok, if you were to take it to an actual car sprayers you would then get it painted and treated to last with a beautiful finish with no streaks, and minimal imperfections.
Hope This Helps
Sir DrowHunter
Freelancing Since 2012
https://linustechtips.com/topic/131920-gold-moded-chassis/#findComment-1755597
