yea its fine, boards are meant to take weight
Specs
https://linustechtips.com/topic/131894-cpu-cooler-weight/#findComment-1755080
Will the asus z87m plus bow under the weight of the noctua udh14 cooler ?
the case I am putting it in is the corsair 350d
As long as the board is properly secured to the motherboard tray it will be fine. I'm sure that heatsinks are designed to have a weight that is not going to damage the board they are attatched to.
PCBs are made from layered fiberglass which is very strong.
https://linustechtips.com/topic/131894-cpu-cooler-weight/#findComment-1755100
im good with tech but how do you know all of this! :o
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/131894-cpu-cooler-weight/#findComment-1755134
