Graphics card sounds like a jet engine
Solved by seban,
4 minutes ago, Garethwahlgren1 said:Hello I have a problem with my 2080ti it only happens when I’m playing games but basically it will run normally for a while but then every 5 min or so for about 15-30 seconds it gets insanely loud and sounds like it’s working really hard then slows down to a normal sound and then after 5 min for 15-30 it will do it again does anyone have any idea what’s wrong with it and how I could fix this problem?
does that happen at idle or when you do something?
Edit: just read "only happens when im playing games"
