Ok, so i Installed the gpu in the pc and the fans spin completly ok, But when I boot up my pc it takes longer to start. And when I try to install geforce drivers it says that I didnt met the requierments to install it. What should I do. Ty. Also sorry for my shit english. Edit: gpu is gtx 550 ti, 1 tb Hard drive, pentium g6400.
https://linustechtips.com/topic/1318184-need-help-with-gpu/
Need to know at the very least the model of GPU, preferably the full system specs.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1318184-need-help-with-gpu/#findComment-14584101
What drivers are you trying to install? The last Nvidia driver release that supported the 500 series cards appears to be 391.35 from March 2018.
Presumably you bought the card second hand. Did you have any way to verify that it functions properly before you bought it?
https://linustechtips.com/topic/1318184-need-help-with-gpu/#findComment-14584147
Yes my friend gave it to me, cuz he bought a new one. Also when I try to connect the gpu to the monitor it says that there is no signal. I just Installed the leatest nvidia drivers btw.
https://linustechtips.com/topic/1318184-need-help-with-gpu/#findComment-14584228
Just now, Majmazze said:
Yes my friend gave it to me, cuz he bought a new one. Also when I try to connect the gpu to the monitor it says that there is no signal, so I had to connect the monitor to the motherboard. I just Installed the leatest nvidia drivers btw. S
https://linustechtips.com/topic/1318184-need-help-with-gpu/#findComment-14584235
Again, what specific drivers did you install? The "latest" ones don't support a 550 ti. Driver support for that card stopped 3 years ago.
https://linustechtips.com/topic/1318184-need-help-with-gpu/#findComment-14584269
2 minutes ago, Majmazze said:
Which drivers should I install
Already told you above the last version that supported the 550 ti.
https://linustechtips.com/topic/1318184-need-help-with-gpu/#findComment-14584566
26 minutes ago, Majmazze said:
Do I have to remove the old intel drivers?
What Intel drivers?
https://linustechtips.com/topic/1318184-need-help-with-gpu/#findComment-14584713
8 minutes ago, Majmazze said:
Intel uhd drivers
No.
https://linustechtips.com/topic/1318184-need-help-with-gpu/#findComment-14584787
