Best Performing AIO
Go to solution Solved by Hyp0xia,
The Cooler Master Glacer 240L outperforms even 280mm options like the NZXT Kraken X60 and Corsair H110. It has a copper radiator, a more powerful pump, wider tubing, and the stock fans have much higher static pressure; furthermore, it marginally outperforms the Swiftech H220 due to its slightly faster pump and higher static pressure on its stock fans. The Swiftech H320, however, beats the Cooler Master Glacer 240L due to the larger surface area, but Cooler Master is supposed to have a Glacer 360L in the works.
I am looking for an AIO that is either a dual 120mm or dual 140mm. I can fit a thick radiator, so that is not a problem, but I need an AIO that cools the best, and I will be replacing the fans with NF-P12 PWM fans, so I don't care about the fans that come with it. And I don't have a budget or it, and I know I could get better cooling from a custom loop, but I need an AIO for this perticular build, so DO NOT tell me to just build a custom loop.
https://linustechtips.com/topic/131797-best-performing-aio/
NZXT Kraken X60 is the best performer you've got to choose from. It is 280mm. The software isn't as good as Corsair Link, but it's good enough.
Want to find parts in your budget? Logical Increments is the guide you need. | In the market for a headset? Read this thread. | If you're looking for headphones, please refer to this thread. | Stop being backhanded when offering advice.
CPU: Intel i7-3770K @ 3.5 GHz | CPU Cooler: Thermaltake Frio OCK | Motherboard: ASUS P8Z77-V LK | Memory: 16 GB Corsair Vengeance LP (DDR3-1600) | GPU: MSI Radeon HD 7870 GHz Edition x 2 (Crossfire) | Storage: 120 GB Kingston SSDNow V300 SSD, 2 TB Toshiba HDD | PSU: Corsair TX850 V2 | Case: In-Win Mana 136 (Black)
Monitor: ASUS VS248H-P | Keyboard: Corsair Vengeance K70 (Cherry MX Brown) | Mouse: Logitech G500 | Speakers: Logitech X-140 | Headphones: Philips Fidelio X1, Sony MDR-X05 | Webcam: Logitech C510
https://linustechtips.com/topic/131797-best-performing-aio/#findComment-1753973
H220/CM Glacier
if u could go 360 h320
Main Rig: CPU: 3570k Mobo: ga-z77x-ud5h-wb :RAM: 8gb kingson ddr3 1600 :gpu crossfire amd 290's Case: zalman z9 plus Cooler: h80i p/p SSD: nutron 120gb HDD: 2tb wd green 4tb seagate desktop
Girlfirends: CPU: 8350 Mobo 990fxa-ud3 Ram 8gb kingson ddr3 1600 gpu: his 7850 case: inwin dragon rider SSD: nutron 120gb HDD: 2tb seagate
https://linustechtips.com/topic/131797-best-performing-aio/#findComment-1753987
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
https://linustechtips.com/topic/131797-best-performing-aio/#findComment-1767859
