OK, so I am a 13 year old kid that knows more and says more than I probably should. I had an account on this forum a while ago, but forgot all the log-in information so here I am to start over. I am now planning to have a build for $500 USD. I already have an XFX 7770, so I am excluding a GPU from the budget. Here is my plan:
Case: Fractal Design Core 1000
CPU: AMD 760K
CPU Cooler: Cooler Master Hyper 212 Evo
MOBO: MSI-A78M-E35
GPU: XFX 7700
PSU: CX430M
RAM: Adata XPG V2 4x2GB @ 1.6 GHz
Storage: WD Blue 1TB
Disk Drive: Whatever is cheapest on NewEgg.
OS: Windows 7 Home Premium 64-bit OR if anyone wants to give me a windows 8 OEM, I hate windows 8.1... with a passion.
Do you think this is a good idea? I am in need of an upgrade for my current PC. It has done me well for the past 3 years, or so, but I need to retire it. Also, with this PC I am looking forward to upgrading it in any way I can when I have the money to do so.
Any CONSTRUCTIVE criticism is welcomed!
[EDIT] I made a new list of parts, some that I think are a better value, and will last longer:
http://pcpartpicker.com/p/34T4C
Edited by REBELBUS
Pentium G3258, R9 270X, 1TB HDD, 8GB RAM, Windows 8.1, crappy EVGA 500W PSU
https://linustechtips.com/topic/131778-500-budget-no-problem/
Are you limited to newegg or are you open to other US vendors?
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1753714
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: AMD Athlon X4 750K 3.4GHz Quad-Core Processor ($79.98 @ OutletPC)
Motherboard: Gigabyte GA-F2A55M-HD2 Micro ATX FM2 Motherboard ($53.98 @ SuperBiiz)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($79.98 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ Best Buy)
Video Card: Club 3D Radeon R9 270 2GB Video Card ($179.99 @ NCIX US)
Case: Zalman ZM-T1 MicroATX Mini Tower Case ($29.99 @ Mwave)
Power Supply: Cooler Master Elite Power 460W ATX Power Supply ($39.97 @ OutletPC)
Total: $523.87
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-03-25 21:27 EDT-0400)
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1753869
CPU: AMD 760K
MOBO: MSI-A78M-E35
GPU: XFX 7700
PSU: CX430M
Do you think this is a good idea? I am in need of an upgrade for my current PC. It has done me well for the past 3 years, or so, but I need to retire it. Any CONSTRUCTIVE criticism is welcomed!
i'd say that's pretty good :)
Linus once unboxed a Toblerone
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1753900
I don't know about xfx quality, I would get a 7770 or 7750 from MSI or Asus. And why do you hate windows 8.1, it is better than 8. Other than that that PC should last you for a while.
Main PC:
ASUS F1A55-M LX, AMD A6-3500, (2x2)gb Kingston HyperX Blu DDR3 1600mhz, Seagate Barracuda 500gb 7200rpm,
 Corsair CX430M, Cooler Master Elite 343, Windows 8.1 Pro 64-bit
Netbook:
Lenovo Ideapad S10-2, Intel Atom N280, (1x1)gb DDR2 667mhz, WD Scorpio Blue 250gb 5400rpm, Zorin OS 9 Lite
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1753942
He already has it.
Its like the SAME Crap.
Win8.1 can have some issues with gaming mice and whatnot that Win8 doesn't have.
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1754021
And its not a driver issue? They should be able to fix that if the driver was for win 8.1.
It may be either just the driver or a Win8.1 issue--don't remember exactly.
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1754072
I am open to other vendors, but I just like to buy things all at once from the same vendor... Never want to send a Newegg return box to NCIX...
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1758149
Total: $523.87
I don't  NEED a GPU, I would like to spend a bit more on the processor and other components. I already have a 7770. Thank you though!
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1758158
CPU:  AMD Athlon X4 760K 3.8GHz Quad-Core Processor  ($84.74 @ Amazon)
Motherboard:  MSI A88XM-E45 Micro ATX FM2+ Motherboard  ($75.99 @ Mwave)
Memory:  A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($67.99 @ Newegg)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.23 @ OutletPC)
Optical Drive:  Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.98 @ OutletPC)
Operating System:  Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($84.98 @ OutletPC)
Total: $513.87
(Generated by PCPartPicker 2014-03-26 18:37 EDT-0400)
It says that the Hyper 212 was not compatible with the core 1000. So i changed it for somthing smaller.
Main PC:
Netbook:
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1758319
I picked the 270 because it is quite a bit more powerful than the 7770
Yes, I know, but I would probably just end up selling the 7770 down the road and getting a different card anyway. I want to have this be as upgradable as possible also.
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1759088
Total: $513.87
I like the idea, but I changed a few things. I might buy the parts soon, thank you for your help guys/gals!
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1759195
They mean the same thing... 4x2 means 8, and so does 2x4... le confuz
4x2GB = four 2GB sticks.
2x4GB = two 4GB sticks
Oh yeah, what's the system being used for?
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1759343
Mostly just some gaming @1680x1050, but not much more. SUPER light video editing, and some music production here and there.
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1761633
Ahh. Regarding your original parts list. The 212 Evo will not fit in the Core 1000.
I'd suggest going with a case like the N200 instead.
Are you dead set on oc'ing?
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1763374
I would like to OC, but its not really top on the list. I plan to upgrade this system over time and if money allows. I made a new PCPartPicker list http://pcpartpicker.com/p/34T4C
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1764460
Edits: http://pcpartpicker.com/p/3hDQo
https://linustechtips.com/topic/131778-500-budget-no-problem/#findComment-1764614
