Need help in case airflow
Go to solution Solved by bowrilla,
Apparently the F12 are intended for airflow orientated use while the P12 are more static pressure orientated - or at least that's what many people say. The fact is: P12 are almost always better whatever you do.
I can't decide between the Arctic F12 PWM PST and the Arctic P12 PWM PST. Which is better for intake/exhaust fan? Front panel has some magnetic air filter, is better to use P12 for intake and F12 for rear?
https://www.arctic.de/en/F12-PWM-PST/ACFAN00200A
https://www.arctic.de/en/P12-PWM-PST/ACFAN00170A
Currently I'm running 2 arctic 3pin fans with a molex adapter, but those are getting noisy after ~4 years of use and I'm looking for replacement with PWM. All the newer reviews are about the P12, is it better as a case fan?
https://linustechtips.com/topic/1317720-need-help-in-case-airflow/
Use the quote function when answering! Mark people directly if you want an answer from them!
