hey everyone,
I need some help here, I just got into PC gaming but I feel I'm running at subpar fps on my games at 1080p. I barely crack 80 fps in any gane I have on my pc/ Granted 80 fps isn't anything to sneeze at but for a 3070 kind of low. My laptop with a 1050 at medium settings would run this. Games at high settings can barely break the 80 fps mark. Any suggestions?
Ryzen 7 3700x
Asus Dual OC RTX 3070
16gb of dual channel ram at 3200
https://linustechtips.com/topic/1317227-low-performance-on-rtx-3070/
If you leave task manager open while gaming (with the cpu tab set to logical cores, by right clicking on the graph) and look at it afterwards, is your gpu maxed out while gaming? Could you post a screenshot of task manager with like the screenshot below?
3 minutes ago, angrykoala01 said:
I have never used a DDU honestly. I just downloaded one from Wagnardsoft how do I go about using it?
Download DDU and the GPU driver, unplug your internet so windows don't do its thing (it'll try to install its own drivers after you run DDU)
Run DDU and install the GPU drivers, you may restart if you wish but I never needed to
-sigh- feeling like I'm being too negative lately
ok I did the clean install and honestly no improvement lol
Can u show GPU usage graph in msi afterburner? While running your games
Cpu usage as well, individual threads
6 minutes ago, angrykoala01 said:
 This is while running the benchmark on GTA 5image.thumb.png.e9cbafa3f72d8debfe7030805759bd79.png
Likely a CPU bottleneck, judging by the high usage on some of the threads
Meaning there's nothing much you can do to improve performance other than:
Overclocking the CPU
Close unwanted background apps
Upgrade your CPU
Explains why you're getting the same fps on a 1050, the 3070 is hardly used (though task manager can't be trusted with GPU usage accuracy)
