Hi, my current system has some Hardware problems and it's an pretty old system. I had enough of this system.
So, i want to upgrade my current system but with budget components.
Here's the components that i'm planning to get:
CPU: Intel I5-10400F
MB: Asus Prime H410M-K
Memory: Patriot Viper Steel 8GB DDR4 3200 MHz CL16
Things i do with computer:
Editing, rendering and some gaming.
Thanks in advance.
https://linustechtips.com/topic/1316877-cpu-mb-and-memory-advice/
might want to get a board other then the h410 platform, made z490, and depending on your gpu, you might not get a huge performance boost from the cpu, so you have to upgrade things that will affect performance.
Don’t take everything I say seriously
take it with a grain of s a l t
A ryzen 3600 + B450/550 motherboard is more worth it in my opinion.
