Budget (including currency): 1000 gbp
Country: UK
Games, programs or workloads that it will be used for: Looking to do 3d graphic design, and play modern games (Warzone, Cold War ect) at max settings with good fps.
Other details No peripherals needed, and I do have some general knowledge on computers. Just seeing if anyone has any good recommendations.
https://linustechtips.com/topic/1316768-budget-gaming-pc-build-help/
Country: UK
When are you planning on buying this? If its within the next couple of weeks then you have to buy a used GPU
geometry is hard
b550 > x570
Just now, Rexoh said:
Planning to buy it by the end of the year, getting GPU last when the new gpus prices have somewhat decreased.
Don't bother planning now. New releases, price changes, etc make it impossible to properly plan a build that far in advance.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Buy a console & build something similar to what downkey has recommended just swap the GPU for a GTX 1660. In a few years when the console starts to show its age upgrade the PC graphics card, at this point ray tracing may have matured to give you AAA titles hitting 120 fps @ 1440p or even 4K with RT on.
