660 ti driver help!
Solved by bradscoolio,
Mash f8 repeatedly after turning your computer on until you get to a DOS screen that'll ask you what way you want to boot. Use your arrow keys to select 'safe mode with networking' you'll be able to go into the site and download the program to install. Then use the program to delete all nvidia display drivers, then you can safely reboot and install the correct drivers :)Thanks! Will I be able to use this before me Pc freezes? ;)
Booting into safe mode boots windows without any drivers so your screen won't go black.
