Android System WebView Update Not Updating - My Solution / Fix
Sorry everyone I am not a technical person, just posting what worked for me after trying tons of common troubleshooting. Apparently this app is a key functionality component in Android for other apps to work like Chrome, Gmail, and non Google apps to function or be allowed to update in the Play Store. And has a history of causing issues with other apps because of this version or previous version of the app itself & with Android 10 and previous versions of Android like android 8. After trying this it work for me on a new phone that came out in January (2021) plus a friends Samsung phone running Andriod 8.
Not saying this the answer for everyone just something to consider, I am not a tech expert.
Long Story short. Figured out a solution that works for me and my new phone (2021) and passing this information so that it may help others Since Google can't and doesn't monitor the app.
Update: Was ask to provide a little more information.
Again keeping it short don't want to write a book on this or the history of the issue.
For some time Android users have been having issues with apps or apps updating and this is because of Android System Webview.
So if anyone is having issues updating Google Chrome, or any other app, or Android System WebView in the Google Play Store this was my solution.
This was done on Android 10 and could be use to solve it on Android 10 and previous versions of Android.
Again worked for me but may not work for everyone.
Latest Update (3/17/2021): A new update for this app showed up. Again it wouldn't let me update it. I tried all the other apps first and they updated. Then before having to try this annoying process again I tried to update it and it did. I don't know what's going on but after doing this solution if you get an update for Android System WebView you have to update all the other apps first before it will allow you to update it.
Solution / Fix
This is a lot of work but it will have the device working better faster than ever. Follow step by step.
Solution:
1) Go to system settings, then apps, click to see all apps.
2) Click on Android Systems WebView then click the 3 dots & hit uninstall updates. Then clear its cache & then clear data.
3) Next, go back to apps list click the 3 dots then choose show systems apps.
Foot Note: On different devices the names will have different variations but it is something like Download or System Download
and the other app is going to be called Download Manager or Systems Download Manager every device is going to be a different variation of the name.
4) But for both these apps you're going to have clear its cache & then clear the data.
Next and this is key follow in this order exact.
5) In system settings under apps and viewing all listed. Go to Google Play Store click on the 3 dots and uninstall updates, then clear its cache & then clear data.
6) Next go to Google Play Services click on the 3 dots and uninstall updates, then clear its cache & then clear data.
7) Key thing to do immediately restart the phone or device.
8) Once the phone or device is rebooted wait like 3 minutes so Google Play Store can load.
9) Very important to do Google Chrome first in the Play Store, I don't know why. Open up Google Play Store and in the search bar type Google Chrome.
Click on Google Chrome and click update and wait to fully finish updating.
10) Next exit out and in the search bar type Android Systems WebView. Do not go to the Beta or Dev versions of it.
Click on the plain regular one. Once inside click update and wait to fully finish updating.
Then exit out. This is what worked for me, may not for everyone but now in your apps you will see they have been updated and actually work better & faster than ever before.
