PS4 Wireless Headphones
Solved by Colty,
https://www.amazon.com/gp/product/B00ZYYPFHU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I got one of these for my GF who's laptop BT was messing up. I did test it on the PS4, it worked great. There is on caveat, the mic out requirements state the following.
"BLUETOOTH VOICE-BACK CHANNEL FOR BUILT-IN MIC | As long as your headset supports both aptX-LL and FastStream codecs, BT-W2 will be able to transmit audio and voice back to the transceiver over Bluetooth for crystal-clear, true wireless communication."
I would expect it to work regardless, but you may want to double check first.
