Before I begin, I need to expression my situation first. I'm planning a new build shortly. However I cannot build it myself. A friend of mine will be doing that. I need rgb fan controller advice. I want rgb, but if I have to not have it, that's fine. I've been planning an all white build, Linus' recent all white build video just encouraged me more.
The case I'm planning to use is the NZXT with an NZXT N7 Z490 motherboard. I would like rgb because as his video proved, it looks wonderful in a white background. Furthermore, it needs a remote controller, hopefully to control the lighting or the fan speeds, but the lighting is mostly necessary. As for why, here's why. I am in a wheelchair. I cannot physically open the case to change these things. As for why that is, and why a friend will be building my pc for me, in 2017, I had a stroke. I cannot physically move my left side. I am in a wheelchair. Being disabled makes certain things impossible for me. I am asking for help here, as my last resort. I asked for help on reddit, specifically r/buildapc, and got none. Any hep would be appreciated. If im out of luck, I'll accept that. If I can get help that would be nice. Thanks in advance. In case anyone is wondering. I'm mostly doing a new build so I can play the new resident evil and the mass effect legendary edition when they drop. You might be wondering, how? I can play games with one arm. It just requires a controller. I have one, specifically modified by Ben Heck, for one handed right arm control. You can see more of that on his websites store. He has them for Xbox one and ps4. I have the Xbox one controller only right now, but out also works with pc, via USB, so I'm good there. I'm pretty sure resident evil will have pc controller support, because 7 did, and the controller support has already been confirmed for the legendary edition. Thanks again in advance.
https://linustechtips.com/topic/1314732-help-controller-advice/
So considering your RGB and fan speed wishes I wouldn't go for an external controlloer (honestly don't even know if that exists) but rather with a controller in the case so that you can change RGB colours and fan speeds in software. If you are able to play games then clicking a few buttons in the RGB software shouldn't be too hard. The controller that I have used quite a few times now and that I can truly reccommend is Corsair's Commander PRO. Comes with plenty of connectors for all your fans and can be controlled by Corsair's iCUE software quite easily. Software works great (unlike some other cheap stuff out there) and Corsair generally has great support (just in case something may not work the way you want it). So yeah, that's what I would reccomend.
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
https://linustechtips.com/topic/1314732-help-controller-advice/#findComment-14556368
there are a ton of controllers out there for both inside and outside of the case, its just a matter os spending time on what works best for you. with this being said most if not all the hubs are inside the case so everything can be connecting to them and then a program can be used to control the RGB. i do know of 1 that the hubs are in side the case but it does have a external remote for controlling the speed and lights. i do have to warn you that this is on the cheap side so dont expect much from it.
Search Results (apevia.com)
https://linustechtips.com/topic/1314732-help-controller-advice/#findComment-14556390
I'm sorry, outside the case? I don't remember typing that, but I am on my phone, and autocorrect is a thing that exists, so I apologize if that happened. I did not need external, I just need out to be controlled with a remote of some sort. Thanks in advance.
https://linustechtips.com/topic/1314732-help-controller-advice/#findComment-14556424
well then look at the link i provided in my comment as these ones allow a remote to be used but they are cheap in my opinion so you might want to look into them more.
https://linustechtips.com/topic/1314732-help-controller-advice/#findComment-14556437
Would the software have any issues with the build I'm planning? Here's the full build: https://pcpartpicker.com/user/DiabeticChocobo/saved/ZCvRK8
If anyone wants to recommend any changes that would be cool, too. Honestly not sure if I would listen to them, though. I'm just glad to be back on Intel, my last build was AMD piledriver. I feel kind of burnt on that.
https://linustechtips.com/topic/1314732-help-controller-advice/#findComment-14556712
an rgb/argb controller with a remote wont be controlled with software...
Edited by thrasher_565
https://linustechtips.com/topic/1314732-help-controller-advice/#findComment-14556753
Im probably going to go this route. I'll try to get video of the build and stuff, to show it off later, if anyone is even interested in that.
https://linustechtips.com/topic/1314732-help-controller-advice/#findComment-14569815
