some people who have gotten 5Ghz on those chips are all running about 1.5V.
i can't recommend you run it at 1.5V 24/7 tough, but for a quick OC session it should be fine.
https://linustechtips.com/topic/1313743-oc-help-needed/#findComment-14547646
7 minutes ago, isicania said:
Hi fellar!
I am currently running a i5 2500k at 4.5ghz and was wondering what voltages I should use for a 5ghz OC. I have a Asus p8p67 Pro motherboard. Tnx!
What voltage is it set to currently?
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1313743-oc-help-needed/#findComment-14547650
don't go beyond 1.45v, preferably below 1.4v
Desktop benching:
https://linustechtips.com/topic/1313743-oc-help-needed/#findComment-14547686
