Hey i need some help with my home network. Recently moved in a house and the internal cable routing options are basically "none". All cables ethernet/coaxial/optical are routed outside of the house fixed to the wall, and holes were drilled . Right now the setup is pretty disappointing, a wifi router from the network provider on  the ground floor and a xiaomi wifi switch for three desktops and a notebook upstairs. But my room where my pc notebooks and smart tv are located are downstairs, on the other side of the house as the router, and for a pc 8/1mbps wifi is just not enough (we pay for gigabit). As all cables are routed outside on the walls i'd like to insert a 2-5 port POE switch somewhere outside under the eaves in a water-free place so i can have ethernet downstairs on the other side of the house. There are no power outlets outside so i was thinking it could be powered by poe.
If there are any options that can be powered by poe (no separate power supply) and have 2-5 ports could you please list them?
If it makes a difference i'm from europe.
Thank you for your help and answers
https://linustechtips.com/topic/1313593-possible-solutions-for-poe-switch/
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
5 hours ago, Slayerking92 said:
@DP_boi
The UniFi Switch Flex is built a bit better for outdoor applications. You don't want any bugs or precipitation getting into those PoE ports.
