GTX 1650 Mobile for OBS Streaming
Can my laptop with Ryzen 3550H 4c/8t 8gb 2400mhz ram gtx 1650m be able to stream games @1080p 60fps on YouTube?
Are the specs enough for streaming?
  • AMD Ryzen 7 5700X Stock
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • Kingston A2000 250gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
Generally I would say yes, but.
It really depends on how demanding the games you are trying to stream are.
I would just give it a try and if the stream lags or you are game isnt running as smooth as you wish maybe try turning down the Video Settings or the Stream settings and for example just stream at 720p or crank down the fps.
