It's just warning you that you'll probably have to do this before it works with that CPU.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1313014-help-about-b550s/#findComment-14541383
Watch the video @Voluspa has linked you, the board you're looking at was possibly built before zen 3 was released, this means it may be shipped with a BIOS that doesn't support the 5600x out of the box. However you can update the BIOS on that board without a CPU installed at all. So nothing to worry about, just be aware of that if you build the system and it wont post.
https://linustechtips.com/topic/1313014-help-about-b550s/#findComment-14541388
