3 minutes ago, Papalapapiricoipi said:
for some reason, any game that the gpu vent plays goes into jet turbine mode
if your fans are too fast, try some software to slow them down. MSI afterburner is free, and lets you control fan speed.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1312063-i-need-help/#findComment-14533918
1 hour ago, Papalapapiricoipi said:
Can someone tell me, use the ventilation of the gpu to the maximum, it takes away useful life from it? for some reason, any game that the gpu vent plays goes into jet turbine mode
As a tip for future reference, try to make your thread title something that's actually descriptive of your problem or question. There are 20 threads a day posted with titles that are just some variation of "Help me."
Are you asking if running the fans on the CPU at high speed a lot shortens their life span? The answer is of course, fans will wear out like any mechanical part will that's used a lot for a long time. Will it shorten their lifespan to the point the fans fail before you're ready to replace the card anyway? That's a different question. Anyway, fans can be replaced.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1312063-i-need-help/#findComment-14534167
