Please help with gpu fans
3 minutes ago, SquiddyButler said:I have a Zotac Amp Holo 3070. My driver's are up to date and I will check bios right now
I did a quick search of Zotac 30 series card on google, it looks like with MSI afterburner lots of people encounter some issues with their fans while try to custom curve, and some of them even stop running.
Base on my own experience, Zotac is not the best in term of quality, my GTX580 got burn out just a few months after building a new system. The quality and the material that Zotac is not intended for OC and therefore I would not be surprised if it does not support MSI Afterburner, or its just the simple quality control issue with the card itself. But a 3070 is a 3070, so look on the bright side, try with Zotac’s Fire Storm, and hopefully it works. And your best bet is to uninstall MSI Afterburner before you install Fire Storm. Cheers!
