Budget  725$ usd
Country: USA
Games, programs or workloads that it will be used for: gaming and streaming
Other details I’m thinking of upgrading an old pc with a new gpu or something it has i3 and 4g of ram and 1tb hdd with windows 8.1 idk what to upgrade I was gonna get 3060  and i510th gen and ram from cor trident and cheap ssd but idk the cheaper the better or should I put like a 2060 or 1660 or 1080 help PLS
https://linustechtips.com/topic/1311376-upgrading-old-pc-help-pls/
Just now, Joshua124 said:
Budget  725$ usd
Country: USA
I can go lower
If you could list your complete system specifications, I am certain we could figure something out.
2 minutes ago, Joshua124 said:
For the old pc ima upgrade ?
Yeah so that maybe you could salvage some parts of it.
I3 with like 3ghz I don’t which i3 it is cause that pc is my attic it’s but it has integrated graphics and 8gb of ram from dell windows 8.1 and 550 watts psu and 1tb hdd
19 minutes ago, Joshua124 said:
Budget  725$ usd
Country: USA
a 10th gen cpu will not work in such an old computer
3 minutes ago, curiousmind34 said:
is but go with it
Cause I do have an i7 that like 3.6 ghz and it’s good with 5 cores I think I’m not sure but it’s from a laptop I don’t think you can put laptop cpu in desktop
laptop cpus don't work in desktops
You should know what is your current motherboard compatibility before going out and buying a cpu, and from there you can find a gpu which would make a balanced combo
Is there anything I can do then give a list for it plz a gpu and cpu and ssd and ram
cuase I only have 600 bucks
Yeah but  600 not gonna be thst good
For 600 you aren't playing cyberpunk, but almost everything else would work completely fine at 1080p 60fps with esports at 1080p 144fps
Obviously you can get better by paying more, but you can get an enjoyable experience for that price.
45 minutes ago, Joshua124 said:
Budget  725$ usd
Country: USA
Somewhat over but you could always go for something like a corsair cx and a 10100
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
