So I bought a 1080 Ti so I can have 144fps always on low settings for my apex legends carrier
But the Gpu is always working around 60 %, it is just not trying to achieve the 150 fps cap that I have set. I have tested the gpu on my friends rig, its working just as it should
I have made a clean windows install, didn't fix the problem
Used Display Driver Uninstaller many times on many different ways, didn't fix the problem
Increased power limits, didn't fix the problem
Updated Bios, didn't fix the problem
Turned XMP on, didn't fix the problem
I stress tested the gpu, cpu, they all work fine at full load without any problems
Cpu isn't bottlenecking the GPU
Temperatures are fine
I am literally losing my mind, I have never heard about this problem in my life. It is just so weird
Pc specs:
1080 Ti MSI Gmaing X 11GB
Ryzen 5 2600
32 GB Corsair DDR4 RAM
EVGA G2 750W
B450 TOMAHAWK
144hz 24G2 AOC monitor
https://linustechtips.com/topic/1310730-my-gpu-usage-is-not-right/
make sure you don't have any framelimit set in your APEX graphics settings or the GPU settings on your pc. Also make sure it is seated correctly. My card is heavy and tends to sag and I noticed a slight performance hit before I reseated it. If this is the issue there's plenty of ways to support the weight of your card in the case
Pc specs:
Ryzen 5 2600
EVGA G2 750W
B450 TOMAHAWK
I'm kind of having the same issue, but i think its my resolution.. have you checked both the GPU and CPU usage during the game session? Use MSI Afterburner's RTSS (riva tuner statistics server)
hi, im renata bliss and am ur freestyle dance teacher
Knock it down to 90 hz and relax.  People who know a lot more about vision than you and I have all agreed that it is nearly-impossible to see faster than that.  Many state that 90% of people can't perceive faster than 60 hz.
I wish I could answer the question you are asking, but might I ask why you are choosing low level graphics with high frame rates instead of a more balanced performance/quality setting?
It must be true, I read it on the internet...
what the hell did you just write xD
there is no framelimit
My gpu is currently in a horizontal motherboard, so I think its okay
my gpu has full load in benchmark tests, so I think gpu is positioned fine
yes, I am using afterburner all of the time
the usage for the cpu is always around at 40 % and gpu is always around 60 %
I'm saying that you should not bother trying to reach that frame rate because it is Imperceivable...
Should you be able to push your GPU to force out that frame rate? in theory yes.  Did I missread your question and think you were saying that even on low settings your GPU was using 60%, yes.  My bad. haha
yeah you missread it
I want to have constant 144hz, I have a carrier in apex, apex isnt that optimized
so if you want to be super good, 144hz stable framerate is a mininium
