my specs:https://support.hp.com/gb-en/document/c03382053
the card:https://www.newegg.com/global/uk-en/msi-geforce-gt-1030-gt-1030-2gh-lp-oc/p/N82E16814137140?Description=GT 1030&cm_re=GT_1030-_-14-137-140-_-Product
hello i am installing a gt 1030 from newegg that im going to buy soon
i need to know if my psu can handle this thanks
https://linustechtips.com/topic/1310709-help/
It will probably be ok.
These low end graphic cards are basically designed to go in pre-built PCs.
The CPU alone uses about 65W.
The GPU is about 30W GPU according to specs, but lets assume it can maybe use up to 75W for what it can consume at most... (PCI-e slot max power delivery)
If we consider everything else... There's no way you're exceeding 200W regardless.
I'd personally say it should be fine with the 300W PSU. Even if it's a low end one.
https://linustechtips.com/topic/1310709-help/#findComment-14523259
My sister's pc was an hp prebuit with a 280w psu and it can handle an i5 2400 and an rx560 just fine . A gt1030 normally has lower power than a gt1030 so its fine.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1310709-help/#findComment-14523263
