Help with multi-gpu crypto mining
Solved by Mick Naughty,
Just make a profile for that card as well when it comes with what ever gpu program you are using.
Undervolt, memory overclock, fan profile ect.
Aside from that not much, just start what ever miner you are using and it will take care of the rest. Assuming you aren’t using something like hiveos.
I wouldn’t use multiple miners, but it wouldn’t hurt. I use one per system. Another miner means a potentially higher dev free or the opposite.
Unless you mean the same miner multiple times, you can’t run multiple instances of the same one.
