Hi
My PC that i built almost a year ago started making a weird noise for a few days and i don't really know from where it comes.
The sound is pretty much random , sometimes start and sometimes stops for a few hours and then starts again.
PC Specs:
cpu: r3 3100
gpu:gigabyte gtx 1660 super
ram: 16gb Vengeance Lpx 3000 mhz
ssd: kingston a2000 250 gb and a 500gb patriot burst sata ssd.
psu:seasonic m12ii evo 620w
mobo: aorus b450 elite.
Sound:
https://linustechtips.com/topic/1310035-pc-making-a-buzzing-noise/
I have bad ears so I cant really hear it. Is it coming through your speakers, or from components inside your PC?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
2 minutes ago, jaslion said:
Just some coilwhine it seems nothing really to worry about.
yep probably this.
Does it get louder and quieter depending on what you're doing or is it a constant buzz?
Personally I find if it fluctuates it tends to be GPU, if it's constant it could be PSU. Not sure if there's any science to that though. lol
If it isn't coil whine then it could potentially be a fan that has developed a vibration, possibly even EMI affecting your speakers
12 minutes ago, Shabba said:
yep probably this.
The buzz remains the same but it doesn't come from the PSU
56 minutes ago, CPatrik said:
You can hear it only with headphones
okay so either interference around the audio jacks by another audio wire or even display cables or it could be your headphones.
Do they have a mic on them? If so does the buzzing still happen when the mic is muted?
Is it just rear audio jack, have youtried front? (assuming they are wired headphones)
Do these headphones buzz on any other devices?
No man , i was referring to the recording
