Will this be okay for a sleeved extension kit?
Tech Reprise
I recently bought extension kits from Cooler Master and in the back of my case the connectors are touching the right metal side panel. Will this be alright? Hope it doesnt cause any shorts.
Also the cables are tightly attached and have clips to lock them in place so I guess they won't snap out of place.
My PSU is a Antec EAG Gold 750W, cables are 16awg extensions from Cooler Master
  • AMD Ryzen 7 5700X Stock
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • Kingston A2000 250gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
The connectors are plastic and routinely touch all sorts of parts of a case or other components.  No worries there.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
16g?  That's a relief to see!  I get sick of seeing all of the crappy 18g extensions out there.
16awg as per coolermaster. Don't know if thats a marketing gimmick or not but package says 16Awg.
https://www.coolermaster.com/in/en-in/catalog/power-supplies/cable-kit/sleeved-extension-cable-kit-white-black/
Mine is a bit different and not listed online
Here is the backside btw. Cables are well tucked in their blankets 😛 And stress testing for an hour didn't start a fire. So I guess I connected everything properly apart from cracking one of the combs ☹️
  • Deepcool AK620 WH
  • Deepcool CK500 WH
16 minutes ago, RR94IND said:
You can buy zip-ties at Home Depot or from Amazon, you know.
I don't think a company like Cooler Master is going to SAY 16g then USE 18g.  That's more like something some shifty Chinese company would do.  Cooler Master is more honorable Taiwan company.  😄
I have zip-ties with me but I have become wayy too lazy after my recovery from Pneumonia to redo the cable work. Maybe will do it in future.
For now if the backside doesn't pose a possible fire hazard I think I should keep it as it is considering the insides look okay.
  • Deepcool AK620 WH
  • Deepcool CK500 WH
