Workstation build
Budget (including currency): $1500
Country: United States, TX
Games, programs or workloads that it will be used for: I’m a graduate mechanical engineering student and was looking for system that could be used for serious CAD workloads. Solidworks, Fusion 360 and Inventor, Ansys CFD, Thermal( mainly design analysis structural, fluid etc.) these are what I require my system mainly for but I do some gaming like COD modern warfare( the only game I play Lol)
Other details I have an old dell laptop which can not be upgraded or would be a pain to so I wanted to buy a whole new system (laptop/desktop/random custom built) while sparing some money on peripherals.
I’m looking to make this purchase as soon as I find a system for the budget. I request y’all to kindly suggest a suitable system with a good resolution and refresh rate based on your knowledge for the above mentioned activity.
Thanks
https://linustechtips.com/topic/1309476-workstation-build/
6 minutes ago, AEB said:
Workstation build
Thanks
Those programs, do they benefit from multiple cores, or the raw speed of a single core? That will help determine if we are looking for a high core count, or a faster lower  core system.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14513179
PCPartPicker Part List: https://pcpartpicker.com/list/XxQNj2
CPU: AMD Ryzen 9 3900XT 3.8 GHz 12-Core Processor  ($479.00 @ Adorama) The 5900x would be better, but it is not available.
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($33.67 @ Amazon)
Motherboard: Asus ROG STRIX B550-F GAMING ATX AM4 Motherboard  ($182.00 @ Amazon)
Memory: Corsair Vengeance LPX 64 GB (2 x 32 GB) DDR4-3000 CL15 Memory  ($323.98 @ Amazon) I figured you might need a lot of RAM. If you don’t, you can save some money here.
Storage: Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive  ($139.99 @ Amazon)
Video Card: EVGA GeForce RTX 2060 6 GB KO GAMING Video Card  ($300.00)  If it ever comes back in stock, the KO Has much better workstation performance because it is based on reject 2080 dies. I figured that GPU performance was not as important as CPU performance for your use case. If you need a GPU NOW, your only msrpish new option would be a 1050ti (or try to get a 3060 tomorrow).
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: EVGA BQ 600 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($74.40 @ Amazon)
Total: $1628.03
Generated by PCPartPicker 2021-02-24 18:41
My primary system: Core I7 10700k, 32 gb Trident Z RGB ram@3200mhz, EVGA GTX 970 SSC (will upgrade), NZXT N7 Z490 motherboard (Black), Samsung 970 Evo plus 1TB SSD, NZXT C850 PSU, Hyper 212 EVO cooler (getting new water cooler soon), NZXT H510i case.
My secondary system: Core I7 4820k, 16 gb quad channel 1600mhz ram, GTX 780 reference, Asus PX79LE, SK Hynix GOLD s31 500gb SSD, some 10 yr old Cooler Master 750w psu, Hyper 212, old Cooler Master case.
Laptop: Lenovo l380 yoga I5 8250u, 8gb ram, 256gb ssd storage)
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14513232
Total: $1628.03
3900xt is useless, get a 3900x. 212 evo is also useless, use the stock coo.er. Ram is overpriced for what you get and It's LPX, Get like a p360a for the case, and get like a neoeco gold or a earthwatts. The BQ is pretty bad.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14513243
Here’s what was recommended to me on pcpartpicker forums.
Your programs are mostly single threaded, so buying a high core cpu as posted above doesn’t help you
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14513260
The xt is cheaper.
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14513261
Do you really think a Quadro is necessary?
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14513263
Maybe, I was just linking what was recommended to me, as I posted in same country with same budget.
and it’s completely different from what you had posted, gives him something to think about I guess.
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14513274
Total: $1628.03
This looks good... thanks
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14513621
Total: $1628.03
This is the best build so far I guess. Thanks
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14513678
The psu is a tier C on https://linustechtips.com/topic/1116640-psucultists-psu-tier-list/.
Quadro would be good except for gaming.
I haven not included a gpu in the build below because ~$400 is not going to buy more than a new GTX 1060 3GB these days. Best to shop local deals for the gpu.
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($299.99 @ Walmart)
CPU Cooler: Noctua NH-U12S 55 CFM CPU Cooler  ($59.95 @ Amazon)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  ($139.99 @ Walmart)
Memory: Crucial Ballistix 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  ($159.99 @ B&H)
Case: Fractal Design Meshify 2 ATX Mid Tower Case  ($139.99 @ B&H)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.63 @ B&H)
Total: $1059.53
Generated by PCPartPicker 2021-02-24 23:53 EST-0500
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14513915
Motherboard: ASRock B550M/ac Micro ATX AM4 Motherboard  ($89.99 @ Amazon)
Memory: Team T-FORCE VULCAN Z 64 GB (2 x 32 GB) DDR4-3200 CL16 Memory  ($247.99 @ Newegg)
Storage: MyDigitalSSD BPX Pro 960 GB M.2-2280 NVME Solid State Drive  ($99.99 @ Amazon)
Video Card: PNY Quadro P2200 5 GB Video Card  ($429.99 @ B&H) look around for deals on a GPU if you can.
Case: Cooler Master MasterBox NR400 (w/ODD) MicroATX Mid Tower Case  ($59.99 @ Amazon)
Power Supply: Rosewill Capstone 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($69.98 @ Amazon)
Total: $1476.93
Generated by PCPartPicker 2021-02-25 02:16 EST-0500
https://linustechtips.com/topic/1309476-workstation-build/#findComment-14514121
