using an antec power supply for mining (see description)
1 minute ago, wabulu said:you are making a really strong point and i agree with it, but does a low load on the power supply will make the chances lower ? for example the tdp of the whole system is about 350 watts i believe
well.. yes.. but i wouldnt even want to use that thing anywhere near it's rated spec for more than a short moment.
i'll put it like this: it's like playing a reverse lotery. drawing more wattage is like buying a bigger ticket, and using it longer is like buying more tickets. eventually you're gonna win the lotery, except this is reverse lotery so winning means losing big time.
i doubt you're gonna hit 'victory' using it as a gaming rig maybe a few hours at a time with lots of idle time in between, but loading it 24/7 is going to hit some unexpected thermal event at some point.
