Water block for a GPU
Go to solution Solved by airborne spoon,
check out alphacool they make water blocks for like 99% of the cards out there
Here is a link to the waterblock for the card you describe
Budget (including currency): Country: Games, programs or workloads that it will be used for: Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Hi i’m putting a system together with some bits I’ve got lying around I want to make it into a custom water loop, the problem is I have a gigabyte auroras RTX 3080 Extreme GPU card, can anyone help, Linus you did a video about this GPU.
https://linustechtips.com/topic/1309094-water-block-for-a-gpu/
hello new member, i pretty sure gigabyte sels a blox for all their 30 series gpus, linus usually doesn't respond if your askin, and please leave the format in place
https://linustechtips.com/topic/1309094-water-block-for-a-gpu/#findComment-14509675
