Stupid MOBO CPU power question.
Go to solution Solved by Jurrunio,
Dont need the 4pin if you have the 8, this is true.
Building a new system using the GIGABYTE X570 AORUS ELITE WIFI mobo. For CPU power it has an 8+4 connections. This is the first mobo I've used with anything more than an 8 pin. I've seen many, many you tube videos where it was stated that unless doing extreme OC'ing that it isn't necessary to plug in the extra 4 pin. IS this accurate?
Second question is I'm using the NZXT c750 PSU and it only has one connection labeled CPU. If the 4 pin is necessary where would it plug into on the PSU? The PSU did come with two cables labeled CPU. Would it plug into an PCI-e slot on PSU?
https://linustechtips.com/topic/1308844-stupid-mobo-cpu-power-question/
Desktop benching:
No, dont do that. Looked up your PSU, you should have 8pin and 4 pin (or 2x 8pin) for the CPU. If you dont, you are fine with 8 pin alone.
Thank you both. I should add that the CPU is Ryzen 5 5600x
That CPU consumes up to 100-120 watts.  Technically, it would run just fine even with just a single  4 pin connector and cable, and with the 8 pin connector it will be very happy.
The extra 4 pin cable would be pointless.
The single 4 wire cable can give around 200 watts to the CPU, and the 8 wire cable is rated for around 330-350 watts (not quite double the 4  wire cable for safety reasons, they intentionally rate it a bit less even though physically the wires and pins in connector are same)
So the 8 wire cable alone is at least 3 times better than what the CPU needs, so adding more wires won't make a difference.
Thank you very much for the detailed answer.
Thank you all for your help. I'm adding this post to say I'm a dumb azz!. The mobo only has the 8pin not 8+4 as I'd thought but I'm grateful to learn something.
I guess I've been looking at so much hardware I got confused. Board won't physically be in my hands until tomorrow
