Solved: Adding a 3th hard drive
Solved by Crimson Lockhart,
I am wondering if i can add a 3rd hard drive (WD Green)
Fatal1ty Z97 Killer
https://www.asrock.com/mb/intel/fatal1ty z97 killer/
SATA3_0--SSD 120GB
SATA3_1--HD WD Black 2TB
SATA3_2--HD WD Balck 6TB
SATA3_3 --HD WD Green 2TB << Trying to add this Solved (replaced the sata cable)
Note: M.2 slot is not in use I don't own one
Other:
PCIE1-- Wifi card << Is this in the wrong slot if so which one to I use?
PCIE2--PCI Express 3.0 x16 Slot-- GPU GTX 1070 (GPU Z PCIe x 16 3.0@x4 3.0)
PCIE4--PCI Express 2.0 x16 Slot-- Wifi card << Is this in the wrong slot if so which one to I use? Edit: Shows the same as PCIE1 (GPU Z PCIe x 16 3.0@x4 3.0)
