I recently discovered that when i have my bluetooth headphones connected it reduces wifi speed significantly, 2,4GHz band to 0,2Mb/s from 20Mb/s and 5GHz band to 2mb/s from 150Mb/s. Is there any fix for this ? It only reduces wifi speed not LTE speed.
I'm running Huawei P30 Lite (MAR-LX1A)
EMUI - 10.0.0383
Android 10
Last security update 1. December 2020
https://linustechtips.com/topic/1308611-bluetooth-reduces-wifi-speed/
Shared wifi and bluetooth antenna can do that, there is not much you can do that about that.
Is there a quick way to find out if your phone uses the same antenna for both? Like is it in the spec sheet and I just missed it?
TUF GT501 | Ryzen 5600X | 32GB RAM | 480GB SSD | GTX 980Ti Hybrid | TUF X570 Pro
Not really, some manufacturers implement this feature well and you dont really notice any issues with both but other than that sadly no way to know.
