Hello,
My specs are:
7700k
850w PSU
Gtx 1070
I put in a second GPU (RX580) in my PC. And when I turned the PC on it made a strange sound so I turned it off. I took out the newly installed RX580 and turned the PC back on. Now there is a red led next to the RAM slots and the screen is black.
Does someone now what the issue is?
Thanks
https://linustechtips.com/topic/1308014-help-please/
You can not run two different kinds of GPUs in the same system. SLI (NVIDIA Cards) only works with the same models and never with NVIDIA and AMD cards together. So most likely you killed your motherboard and or RAM by doing what you did.
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
https://linustechtips.com/topic/1308014-help-please/#findComment-14501000
