Alright so I recently moved on from consoles to make my first pc and here’s the build:
MSI VGA RTX3080 VENTUS
2x8 3200 MHZ
850 WATT GOLD
RYZEN 3800x 8 core 16 thread
MB GIG X570 UD
with this build I was under the impression that I would get a good performance (160 fps+ or so) but NO MATTER what settings I run the fps stays between 40-80 never more, on games such as Cyberpunk, State of decay 2, Warzone, Minecraft.
My temps never go up beyond the 70s task manager says the cpu is at about 50% and gpu at around 70-90% with cyberpunk for example, but any of the following: ultra settings, medium with rtx, low, medium. i keep getting around the same fps, it doesn’t drop with upping the settings, or rise when I lower them.
I ran some benchmarks and they all give me too tier performance but the games don’t match up to that.
I checked my drivers they’re all up to date and did the (optimize) option from GeForce experience and all is still the same.
I’m running out of ideas please help.
https://linustechtips.com/topic/1307866-rtx-3080-build-underperforming/
On 2/20/2021 at 6:40 PM, A.Hruskach said:
Try enabling Gsync or Vsync. My system did that with Call of Duty: Modern Warfare, and when I enabled vsync, i gained 20ish fps. I also looked for framerate caps in my game settings and Nvidia Control Panel.
Done all of this the issue persists, I took it back they said they’ll run a full check and replace any faulty components.
