Budget remaining: $1500 AUD
Country: Australia
Games, programs or workloads that it will be used for: Casual QHD gaming and web surfing including youtube.
I already bought the following and it's too late to turn back unless I need to return any of them:
MSI B550 TOMAHAWK MOTHERBOARD
AMD Ryzen 5 5600X CPU
Cooler Master MWE 80Plus 750W PSU
Cooler Master MB520 RBG ATX Mid Tower CASING
I now just need to buy a GPU and MEMORY
I'm conflicting between the RTX 3070 and the RTX 2080 super for the GPU. I really just need help with the final two on my list and what is compatible. I'm planning to get 3200mhz of RAM but I have no idea where to start. I would also like to mention that most of the GPU in Australia are either out of stock or very pricey (even more pricey than before).
I already have the NVMe SSD and HDD I want to use. Thanks in advance 🙂
January 2025 PC BUILD | White Aesthetic
Case: Corsair iCUE 7000X RGB CPU: AMD Ryzen 9 7900x (Zen 5) GPU: Gigabyte GeForce RTX 4070 Ti SUPER AERO OC 16G Motherboard: Gigabyte X870 AORUS ELITE WIFI7 ICE (AM5) RAM: G.Skill Trident Z5 Royal Neo RGB 32 GB (DDR5-6000 CL28) CoolerCorsair iCUE LINK TITAN 360 RX RGB PSU: Corsair RM850x SHIFT (White) Storage: Corsair MP700 PRO 1 TB, 2TB Corsair MP600 Elite Case Fans: Corsair iCUE LINK RX120 & RX140 Monitor: Samsung Odyssey G70B
Built for casual 4K gaming, future-proofing, and a clean white aesthetic.
https://linustechtips.com/topic/1307807-help-with-finalizing-my-build/
If you can get access to 3070 at a decent price, it's a no brainer.
For ram, get the one with the best / easiest after sales service, most of them are the same and have lifetime warranty.
If the distributors are in your area, get that.
Country: Australia
For RAM, go with 3600 MHz RAM with CL 16 or 18, whatever you get. You can use HyperX or Crucial Ballistix memory. For the GPU, I'd suggest to go with the RTX 3070, which is faster than 2080 Ti, but considering the time, you'd probably have to get whichever is cheaper (considering the second hand market for 2080 ti), and both are good.
Attention is what makes life meaningful.
Also, please quote me for a reply. 🙂
Yeah I was going to go with the 3600mhz but I thought going with the 3200mhz to be on the safe side because the motherboard specs show that anything above 3200mhz is (OC) which i know is overclock obviously. There have been issues with this motherboard and the 3600mhz speed.
AMD processors like 3600MHz so yea you could go with what Anirban said, Crucial Ballistix Memory.
I highly doubt there'll be a good price on a 3070, but if you find one for a good price, I suggest going for it before someone snags it up.
→  Kindly quote or mention me if you would like a reply back.
<famous quote>
Can you show me any links to where this issue has been elaborated? Otherwise OC RAM is perfectly fine. Just beyond JEDEC standards.
Country: Australia
Is that psu the MWE Gold ?
As for the Ram any 3200MHz CL16 kit is fine. If you can get 3600MHz CL16 for the same price then take that. Otherwise it isn't a huge dealbreaker in terms of fps.
