what do you have already?
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/130775-going-to-microcenter/#findComment-1740658
4770K (or 4670K idk) MPower bundle.
I have a micro center 30min away and have never been :(
I have a Microcenter an hour away and I bought my 8350 there. I'm going to try and buy a 4670k or 4770k there when I rid of the 8350.
Check for open box items. One of my friends who lives closer buys almost everything open box and built his rig for nearly half the price. Granted, he probably doesn't have a very good overclocker.
if you have to insist you think for yourself, i'm not going to believe you.
https://linustechtips.com/topic/130775-going-to-microcenter/#findComment-1740677
@Shd0w2
Buy an i5 4670K and a gigabyte GA-Z87N-Wifi
You'll get $30 off the motherboard and the cpu is $50 off
It'll total to ~$320 after tax rather than $380 at newegg.
Then sell it to an LTT member via the classified section for $340 and have them pay shipping and understand that the item is essentially as is.
Continue doing this until you have a $300 profit,you can only buy one processor/mobo combo per day, and then be ready for maxwell SLI.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/130775-going-to-microcenter/#findComment-1740738
What should I get? Im clueless what to get :I I have $300. can spend a bit more if needed.
A 4670k combo with some motherboard, another 770, more ram, a new headset if they carry any.
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
https://linustechtips.com/topic/130775-going-to-microcenter/#findComment-1740775
@Shd0w2
Naw... I'm too lazy to do that, and its almost 3 hours away from me, I already have and 8350 which I plan on getting an 880 and h100i later.
Diamond 5 in League :)
https://linustechtips.com/topic/130775-going-to-microcenter/#findComment-1740777
