Just now, Dunne Djan said:
ohhhh yeah i tought of it, is upgrading to an i9 10900K worth it?
Well, to get any meaningful upgrade, you'll need to do a full CPU/motherboard swap, as the 7700K is the best of the best for LGA1151v1.
I'd advise getting a 5600X plus a good B550 board.
What RAM do you have?
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1307652-rtx-3070-load/#findComment-14498499
i want intel im using 32bg ram corsair 3200mhz
https://linustechtips.com/topic/1307652-rtx-3070-load/#findComment-14498502
I prefer intel, ive got it always
I'd make a separate thread on a build; I'm not great at putting together build lists.
Though I guarantee you'll get 5600X recommendations.
https://linustechtips.com/topic/1307652-rtx-3070-load/#findComment-14498629
1 hour ago, Dunne Djan said:
Hi, i own an rtx 3070 with i7 7700K but when i play gta i get 60 fps i also see that my gpu load is at 40% how do i get 100%? more fps?
If you constantly get 60fps all the time then you might have vsync locked at 60fps.  I have an i5 4690K and a 1070FE and I fluctuate between 70-100fps at 1080p.
Turn off vsync.  Go to your nvidia control panel and make sure it's not locked.
https://linustechtips.com/topic/1307652-rtx-3070-load/#findComment-14498666
Just now, Doug_Dangger said:
If I remember correctly I recall one of the youtube tech guys (dude from south Africa) reported that AMD is experiencing a 20% failure rate on the 5000 series chips.
The tweet that said that was deleted, and no other proof has been given for this.
https://linustechtips.com/topic/1307652-rtx-3070-load/#findComment-14498680
