ryzen 7 5800x cooling solution
3 minutes ago, jpnrr_ said:
is the h100i elite capellix 240mm enough to cool? i will just play games and normal daily using.
The 5800x is a really hot cpu. If you're gaming I'd just go for a 5600x. It'd probably be fine but still, there's no real reason for you to get a cpu with more cores if you're primarily gaming. Also wouldn't really reccomend the h100i lol, I'd go for a deepcool ex aio or a arctic liquid freezer ii aio If I had to go for an aio, for a 5600x even the stock cooler would be fine.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
