Hey guys,
I made a system about 4-5 months that I use. Lately I decided to try to overclock for some extra performance. Under stress testing, I got some abnormal temperatures compared to tech sites and other people around on forums. I run a Intel i7-4770k stock clocks and a Asus GTX 770. When I stress tested the 4770k, I got temps at 90-95 degrees celsius cooled with a h100i (!) in Prime 95. My Asus GPU hits the thershold at 80 degrees stock  in Furmark. This makes me wondering how everybody else is getting these overclocks and still remain at a good temp. For additional cooling, I got everthing housed in a Fractal Design Arc Midi R2. 2 Noctua NF-A14 bringing air in as well as I turned a Corsair AF 140 around to be intake fan from the back, just for possitive airflow.
Hope for some good answers and solutions for what I can do to improve my temps.
https://linustechtips.com/topic/130693-abnormal-high-temps/
4770k always had a bad thermal paste under the heatsink.
Try delid it. Or maybe you put the cooler wrong on the CPU, try to Reapply the cooler on it
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1739662
Reseat the CPU cooler. Corsair i Series coolers have a retarded mounting mechanism that often leads to the block sitting half on the CPU. It happened to me. I reseated and got a 15 degree drop @ 4.2Ghz.
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1739687
Deliding is not an option as it is my first computer, and I´m am quite new to the overclocking thang.
Done this three times already, as well as reseting the thermal compound. Didn´t get any improvements.
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1739714
dont use prime for haswell and dont use Furmark at all.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1739720
What should i use then.
Aida64, occt for Haswell and games/synthetic benchmarks like heaven and valley for gpus.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1739747
Use OCCT to stress test. Reseat cooler as said before. You should get around 65C with stock clocks. Check what volts are when you are on max CPU use. Those make big difference with 4770K.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1739767
What do you mean by reseating it? I don´t know if I get what you mean.
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1739816
Reseat = Take cooler off CPU. Remove thermal paste and clean both CPU and copper plate of cooler. Apply new thermal paste and place cooler back. Tighten it and try again.
Most times when I read high temps on H100/i are because it has been bit loose.
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1739825
Think I fix it this time. So after some searching on the interwebs, I noticed that many people were complaining about loose mounting with the H100i. I then went full MacGyver and used the washer from the screws to the H100i and used it with the stand off screws for the cooler. It is much tighter now and temps are now topping 75 in occt.
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1740085
That sounds better. Reason why temp is still bit on high side for that cooler is because default volts being too high.
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1740104
Any solution for this problem?
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1740143
You mean volts? You have to set LLC from BIOS to highest possible and manually set volts to something under 1.2V when running on stock clocks. Finding lowest stable volts is part of OC process anyway.
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1740603
Thanks, after some tutorial watching, I have started to overclock and so far I got 4,4 Ghz on 1.25 volts.
https://linustechtips.com/topic/130693-abnormal-high-temps/#findComment-1742529
