Hello Community,
Is been a long time since I was here.
I'm planing to build a new PC,for be more specific it will be a Gamestation.
What I wanna say with that is, It will be like a Cube and connectet to a 32'' LED TV and controlled only with the Razer Sabertooth(in Games)/Like a Better PS4 od XBONE
MY budget is arround 2000USD(1800Swiss Franks)
Here The specs:
CPU:      Intel I5 4670K
MB:        Asus Z87 TUF Gryphon m-ATX
RAM:     2x4GB Crucial Balistix Tactical CL8 1600Mhz
Graphx: Sapphire R9 290X Tri-X    (I'm NV fan but spend arround 100 more for 3 FPS no thanx and the Tri-x seems to be faster than a stock 780Ti)
Storage: Crucial M500 480GB SSD (no HDD)
Cooler:  EKL Alpenföhn K2 CPU Cooler
No DVD or Bluray Rom
PSU:     Be Quiet! Dark Power P10 550w
Case:    Aerocool DS Cube
Question:
will be the 550w enought for the system ?CPU and GRFX will be in future be OCed
thanx for the answers
https://linustechtips.com/topic/130690-project-gamestation-2014/
I would pick up a gtx770 instead, they are only 260€ on some german websites and they run cooler than the r9 290. I would also only get a smaller SSD like a 128-256gb model, because a HDD is fast enough to load most games and I've only noticed a big speed difference in BF4, but not that much, that I want to move my whole library to the SSD and you would like a HDD for Storage of other things too. since you want to use the PC solely for gaming I would suggest getting a lower end I5 or just the 4670 non-k
ps: the powersupply should be enough for a i5 and 770(not quite for a r9 290 though)
https://linustechtips.com/topic/130690-project-gamestation-2014/#findComment-1739635
480 GB total seems a bit small, Id recommend getting like a 250 GB ssd and like a 2 TB HDD.
Also 550W is enough for any single gpu build. I dont get why people always seem to have these outdated or just wrong oppinions. to prove my point:
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/130690-project-gamestation-2014/#findComment-1739650
a HDD will not be monted thats why I choose 480GB SSD It will only have OS and Games inside
its only for gaming
for work and other things I have a Notebook :)
and why 770?
is a bit a distance from the 290x to the 770 isnt it?
and it should run for 2 Years all the Games @ Ultra or Very High
after 2 Years maybe I'll change the GPU
and thanx I'll let the P10 550w on the list
My budget was @ beginning about 2500Dollars
780Ti on the list a expensive board and watercooler
and after few thinking came 500 bugs down :D
https://linustechtips.com/topic/130690-project-gamestation-2014/#findComment-1739718
its only for gaming
and why 770?
oh, sorry...I read that you wanted a r9 290, but you actually wrote 290x. Those two cards can get pretty hot so the fans might spin loud and I know that the 770 runs quiet
believe us though with the SSD and HDD. You'll regret spending so much on the SSD and not having enough space for everything
https://linustechtips.com/topic/130690-project-gamestation-2014/#findComment-1739891
Where are you shopping?
and why 770?
The 290x is quite overkill. There's also no reason to get the 290x over the cheaper 290. You should probably stick with the 770/280x or get a 290/780 after upgrading your display.
hehe ok
yes thats why I choose the Sapphire Tri-X in tests only runs untlil 72-75° and easy quiet.
about SSD I know that after few games will get full
but I'm planing later to mount another 480GB SSD
but only later :)
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Why not a hdd instead?
https://linustechtips.com/topic/130690-project-gamestation-2014/#findComment-1742349
im shoping here www.digitec.ch
Switzerland
About HDD is,I dont know for what I will use it
It will only have the OS a few games inside
Thats it
Like a game console hehe(just with ultra graphics)
And why I wanted the 290x is
My wish is to play 2 years on ultra settings without microstutter
Or is there another possibility?
https://linustechtips.com/topic/130690-project-gamestation-2014/#findComment-1747303
