Setting up freesync without adrenaline?
Go to solution Solved by Skiiwee29,
No, you have to have Adrenaline installed to be able to enable Freesync.
I want to set up freesync on my pc but if possible without having to install adrenaline software since so far i have only bad experiences with it.
my monitor is a viewsonic XG2405
pc specs are
i5-7600 cpu
z270 motherboard
2 8gb DDR4
5600 xt gpu
Current gpu drivers should be 27.20.14501.28009
Is there a way to install radeon software (which is apparently the amd version of nvidia control panel) without also installing adrenaline or if there is some other way?
https://linustechtips.com/topic/1306792-setting-up-freesync-without-adrenaline/
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Unforunate to hear that but guess i will have to deal with it
Just to make sure though there is no such thing as radeon lite or whatever that could be used as a general alternative right?
ikr amd would be so cool without their pesky drivers, but unfortunately that's not how it works (somebody should mod NVCP to work with AMD cards tho...)
-Scott Manley, 2021
