Xfx590 fatboy 8 gb with ryzen5 for 1080p 144hz ?
Solved by TheInfinityBacon,
It really depends on the games you are playing. The RX 590 is definitely capable of high FPS gaming, especially on esports titles like League of Legends, Rocket League, and CS-GO, where higher refresh rate really helps. A higher FPS monitor usually shouldn't negatively impact visuals on more demanding games, unless you turn on V-Sync, and start to see stuttering from my experience (leave V-Sync off is the conclusion). If the monitors have Freesync, just enable that, and your monitor will match frame rate with what the graphics card puts out (down to a limit of usually somewhere around 40 FPS)
If both of the monitors are a similar price, I would absolutely choose the 144Hz monitor.
