I was downloading the drivers for the motherboard on the MSI official website, after I had downloaded them I was installing a few when one asked for a restart. So I did it. But now my computer won't turn on. The LED's on the top - right corner of the motherboard (on the corner of the RAM) turn on with the CPU one turning on first for a couple seconds, then the DRAM one and then it goes back to the CPU one for a split second. The LED's on my GPU also turn on for a couple seconds (as they normally would, but I like to have them turned of so they turn off, they still turn on for a bit when I normally start my computer), until the whole PC starts again. During this whole process nothing ever comes up on my monitor. I have also tried to turn the power supply off, wait a couple minutes, and then turn it on again, but the same thing happens. I also tried to unplugged everything (other than the power supply cable, but including the display port cable) and the LED stays on DRAM for longer now, around 5 seconds. I have done some research online but I wasn't able to find anything, it would be great if you could help. Thanks!
Motherboard: https://www.msi.com/Motherboard/MAG-B460M-MORTAR-WIFI
Edit: Added a video which shows what happens (sorry for the low quality)
Edited by Agastyag53
I forgot to add the video.
https://linustechtips.com/topic/1306458-pc-not-opening/
Try doing a CMOS clear/reset.
Which driver installation were you on that prompted the failed restart?
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1306458-pc-not-opening/#findComment-14489538
