Mhz vs CAS
Go to solution Solved by AlwaysFSX,
Take CAS, divide by MHz. That's the time it takes ram to do something. Lower number is better. @TheNinjaNextDor explains what each is.
CAS is latency and MHz is the frequency.
Most of the time a very high MHz and a high CAS latency cancel each other out.
Performance wise though like how do they compare in numbers? Is there a way to know what is faster than what (without testing obviously)
https://linustechtips.com/topic/130626-mhz-vs-cas/#findComment-1738819
Just look at the MHz and CAS.
1600MHz CL9 RAM is much slower than 2400MHz CL9 RAM.
There is less of a difference here: 1600MHz CL9 RAM is less slow than 2400MHz CL10 RAM than in the example above etc.
https://linustechtips.com/topic/130626-mhz-vs-cas/#findComment-1738824
