Hello Forum,
I have a big problem, with one of my R9 280X, the fans are not spinning propertly, one of the fans will spin for a bit and then stop and then spin again and stop, the other fan will not spin un less I mannualy help it. I am thinking that the oil spilled or something. I have only had the card for a few months so Im not sure what it could be. I am thinking on taking it apart and cleaning it and maybe oiling th efans, but as this will void my warranty what do you guys suggest I do
Thanks
fez
https://linustechtips.com/topic/130570-help-help-help/
Best thing to do is RMA.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/130570-help-help-help/#findComment-1738079
RMA, don't take it apart or fiddle with it just send it right on back to be replaced.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/130570-help-help-help/#findComment-1738101
well I managed to take the forn off with out going throw the back (where the warranty sticker is) and I will try and oil them tomorrow and see if it helps, if not then I will send it back. Thanks for the thougths
fez
I think you might void your warranty if they see that you have oiled it.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/130570-help-help-help/#findComment-1747055
