So I built a system with a X99-A motherboard. I keep getting told that it has built in wireless WIFI. I bought the motherboard off of eBay, and didn't get anything except for the IO shield and the motherboard. I keep seeing that the X99-Deluxe comes with antennas for wireless WIFI, so I'm wondering if this is the same with the X99-A. I'm trying to set  up wireless WIFI right now, so I'm taking all the help I can get. Could anyone help me out?
PCPartPicker Part List
Type Item Price
CPU Intel Core i7-5930K 3.5 GHz 6-Core Processor Purchased For $50.00
CPU Cooler ID-COOLING SE-914-XT Basic 45.8 CFM CPU Cooler Purchased For $24.00
Motherboard Asus X99-A ATX LGA2011-3 Motherboard Purchased For $150.00
Memory G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory Purchased For $40.00
Storage Kingston A400 120 GB 2.5" Solid State Drive Purchased For $20.00
Storage Hitachi Ultrastar 7K4000 2 TB 3.5" 7200RPM Internal Hard Drive Purchased For $40.00
Video Card Sapphire Radeon R9 280 3 GB Dual-X Video Card Purchased For $81.00
Case Thermaltake Versa H21 ATX Mid Tower Case Purchased For $48.00
Power Supply ARESGAME AGV 500 W 80+ Bronze Certified ATX Power Supply Purchased For $45.00
Operating System Microsoft Windows 10 Home OEM 64-bit Purchased For $18.00
  Prices include shipping, taxes, rebates, and discounts
  Total $516.00
  Generated by PCPartPicker 2021-02-13 20:02 EST-0500
https://linustechtips.com/topic/1305645-x99-a-wireless-wifi/
It may still have the empty slot for the WiFi card hidden under the IO shield, but as the shield itself wont have the antenna ports it would need some DIY to do it that way.  Easier to get a PCIe card with it all included.
https://linustechtips.com/topic/1305645-x99-a-wireless-wifi/#findComment-14482674
