Grandma's laptop has really low storage
Solved by jaslion,
Yeah that is also an issue as with that low space windows will refuse to update. Did you install 32bit or 64? You upgraded right? That means windows will leave a fair bit of trash data so you can delete that usually in a place call windows.old.
The micro sd solution can work but micro sd cards aren't that durable so if it gets used for virtual memory it will wear out soon or as recycling bin space so make sure to turn that off so it doesn't start doing it. It is still basically like a usb stick.
The real solution is to get an actual laptop (some older used dell like a e7440 is about 200$ so not much and miles better than the celeron on pentium I assume is in here).
