Budget (including currency): £500
Country: England
Games, programs or workloads that it will be used for: Twitch Live-streaming.
currently streaming minecraft and it runs fine but wanting to expand to other games. Also when using animated overlays in stream labs it makes everything slowdown and be unusable, so I’m stuck with normal overlays sadly
current rig
mobo- Gigabyte AB350m gaming 3
ryzen 3 1200 CPU
1050ti 4GB GPU
16GB 3200MHZ Corsair RBG Ram
1TB WD blue HDD
1TB WD Blue SSD SN550
450 Bronze PSU
Edited by maidens97
https://linustechtips.com/topic/1304109-what-to-upgrade-first/
Any Ryzen 6 or 8 core, 2000 series and up depending on what you can actually buy for a decent price
GPU is fine for 1080p gaming and nothing else is in stock anyways wait until the RTX 3060/ 6600/6700 XT for that
oh wait I don't know what that board supports, probably only up to the 2000 series
https://linustechtips.com/topic/1304109-what-to-upgrade-first/#findComment-14469697
What motherboard do you have? I'd probably suggest upgrading your CPU and motherboard. If you have £500, you can probably get a new motherboard and CPU, so I'd suggest doing that. Everything else would be fine with that. GPU is fine for 1080p gaming.
https://linustechtips.com/topic/1304109-what-to-upgrade-first/#findComment-14469702
