customer brought in a custom pc that we replaced the motherboard on 4 months ago. Now its back in the shop because none of the usb ports on the board or through the front IO are working. We have tried an in place upgrade, BIOS update, cleaned the pads on the CPU, moving RAM to a different slot, and tried a different power supply. The ports will randomly work but if you restart the pc they quit working. Any ideas would be helpful, we do not have anther motherboard compatible with the CPU and were wondering if the CPU or the bios controls the usb functionality. Build below.
Components:
CPU i7-7700
MotherBoard ASROCK B250 Gaming K4
8GB RAM
https://linustechtips.com/topic/1303090-usb-not-working/
USBs come from the chipset, so probably dead mobo.
F@H
GPD Win 2
https://linustechtips.com/topic/1303090-usb-not-working/#findComment-14461574
Components:
CPU i7-7700
8GB RAM
Have you checked the ports themselves or the case?
https://linustechtips.com/topic/1303090-usb-not-working/#findComment-14461609
1 hour ago, techthomaspro said:
Thanks and damnit the board is 4 months old
Well that's what warranty are for. Lucky for you it doesn't break at the 366th days.
https://linustechtips.com/topic/1303090-usb-not-working/#findComment-14461756
unfortunately in order to get the customer the same motherboard for the price we wanted we had to get a used one and that warranty is only 90 days.
https://linustechtips.com/topic/1303090-usb-not-working/#findComment-14461850
If the board was only 4 months old it should be under warranty to be RMA'd. Why wouldn't you pursue that before replacing it with a used board
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1303090-usb-not-working/#findComment-14461860
send it for RMA and change it back when its ready.
you got  to be transparent with your customer.
They must know the risk of buying a pc.
It's not your fault the mobo failed, probably its his negligence.
https://linustechtips.com/topic/1303090-usb-not-working/#findComment-14462487
