Basically my brother has a old computer of mine and the other day it started glitching and lagging when ever he played minecraft or tried to edit videos for his youtube.
I have tried to delete minecraft and looked around online to see what could be wrong but couldnt find anything, i was thinking its a hardware fault with the graphics card so i changed the graphics card and put a 7870 in there
but yet it kept happening,im still thinking that its a hardware issue, maybe his motherboard or maybe the cpu but im not 100% sure on what it is.
Does anyone know what it could be, I didnt know if its worth changing some parts but then it might not fix it or completely changing the parts and starting fresh.
https://linustechtips.com/topic/130301-computer-problems/
Not very descriptive - please list out all the system specs. Does it only lag when playing minecraft?
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/130301-computer-problems/#findComment-1734864
As i said its when ever playing minecraft or editing videos so and the parts are
Intel i5-3550 cpu
GigaByte Z77M-D3H-MVP
ATI Radeon HD6670
Seagate Barrcuda 1TB
Corsair Vengeance 8GB
ThermalTake V3 Case
Gaming PS 500w
Running Windows 8 64 bit
https://linustechtips.com/topic/130301-computer-problems/#findComment-1734905
if it's a old system then it's the ram and the CPU :/
yeah i was thinking that, but then i was also thinking the power supply due to the fact that the computer gets very hot due to not having much airflow and being in australia its very hot so i thought it could get hot from that
https://linustechtips.com/topic/130301-computer-problems/#findComment-1734911
That may be your issue - dust out the system and make sure you have adequate airflow... maybe a new case with better airflow would be better?
https://linustechtips.com/topic/130301-computer-problems/#findComment-1734918
I will try that, but could it have already damaged the parts in the system?
Highly doubt it. Most of the time the PC will turn itelf off if a component gets too hot.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/130301-computer-problems/#findComment-1735005
I did but it didnt fix anything, its not the graphics card. Both of them work perfect because i tried them in my system
try running the system with everything outside the case and put a fan on the ram test if that fixes it. if it does then you need a better case with more fans
https://linustechtips.com/topic/130301-computer-problems/#findComment-1742727
one more thing you need to take into consideration is that minecraft runs with java meaning more cpu power than gpu so it might be a simple overheating issue, so as said check the your heatsink if your using one make sure nothing is wrong there then if every thing is okay make sure you are running the latest java 64-bit version.. good luck :D
I Listen. i Observe. I Learn. I make my own decision
https://linustechtips.com/topic/130301-computer-problems/#findComment-1744905
